no that is currently not possible (also it is not necessary to ask both in the forum and via support)
Best regards,
Marcel
2019-01-24
Originally created by: KevinR
Thank you for the answer.
I thought it might be helpful to ask this to the community.
So it could also help others if they are struggling with the same problem or if someone is looking for a similar solution.
So back to topic
I did a little workaround for special umlauts. They can be used by pressing ALT+u to get a ΓΌ, and so on..
It might be not the best solution but it works well. I execute a ST Code and push the correct Character code if the combination is pressed.
Let me know if it is planned to support more characters in the future.
BR,
Kevin
Gesendet von meinem LYA-L29 mit Tapatalk
is there an option to use special characters for key inputs in the visualisation?
Best regards,
Marcel
So back to topic
BR,
Kevin
Hello sir,
no, nothing is planned in this direction.
Best regards,
Marcel
Hello Marcel,
thanks for the info.
