Im working with a visu where I have two trend visualizations, one for analog values and other for boolean values.
I will like to see the same timescale in both trends to be able to visually compare data with the same timescales.
I can adjust timescales on each trend manually using the "data range picker", one for each trend, but ideally,I will like to have only one "data range picker" and one "time range picker" for controlling both trends at the same time. Is that possible?
Going deeper on the propierties of the element "Date range picker", I see that you can assign it to a trend using the property "attached element instance" but i cannot select it to control more that one.
Hi All,
Any ideas?
Thank you very much for your time!
