I have designed a small program on my cMT3092x HMI with some switches, lamps and text fields. Whenever I do an offline or online simulation on my computer, I can see all the switches and lamps on my computer.
But when I download the program to the HMI, only the text fields are left, and I can't see the switches and lamps I've created on EasyBuilder Pro. Does anyone have any idea what the problem might be? The message "Device No Response" also appears. Is my HMI not connected to the PLC properly?
Thanks in advance.
Last edit: mrcosta 2021-06-24
I have the same issue with my cMT display. I know it's a communications issue with my Eurotherm E+PLC400 PLC using the Codesys V3 driver. Were you ever able to figure out what the problem was and if so, what was your fix. Any help would be greatly appreciated.
Good afternoon,
Thanks in advance.
Yeah, "Device No Response" indicates there is no connection to your HMI.
Best regards,
Marcel
