Integer Addressing at the Bit Level
ali.khalil
2018-05-29
2018-05-30
  • ali.khalil - 2018-05-29
    Hi all,
    I am using CODESYS for the very first time. The problem I am facing is that I have an integer in the PLC code and I am using each of the bits to control a coil.
    In the visualization I created 13 buttons to control Int.0 to Int.12 but for some reason all the bits in the second byte of the Int are not responsive. to overcome the issue I had to write a value to the integer instead of changing individual bit status.
    Does any body know why this is happening, why can't I toggle Int.8 to Int.15 from the HMI.
    Thank you.
  • plcmax - 2018-05-30
    Which platform / device are you using?
    Cheers
    plcmax
