I played with the SFC Visu Generator , to display an SFC program , which has some Parallel branches
In my test , i have observed the following:
On entereing Parallel branches , the Visu shows this correctly (The first steps are active) , but as soon as one of the branches continue - (Next step in this branch) , the Visu will not correctly show active steps on the other paralell branches
Is there a way to accomplish this ?
I attached 2 images, to show this situation, 1 for the running plc program , and 1 for the visu screen..
TIA
Frank S
I am also interested in this topic.
It would also be very nice if the SFV Visu Generator would create visualizations for sub-SFCs, i.e. SFCs that are inside the SFC-steps.
Right now they seem to be ignored.
What I understood from the gernerated code is, that the -Variable is used. This seems to be bad for sub-SFCs and parallel branches, because the -variable only shows the name of one step, while there are much more active in parallel.
WouldnΒ΄t it be better to generate code that asks for the implicit <stepname>.x</stepname> variable for each step?
It is possible to manually change the automatically generated highlighting code to look for the .x, but the automatic generation would be much nicer.
Best,
Martin
TIA
Frank S
Best,
Martin
