Textfield display problem
tristan
2025-11-20
2 days ago
  • tristan - 2025-11-20
    Hello everyone,
    I have a little problem with textfield display. When I put a solid backgroud, no problem. But when I put it to invisible, some strange things appears with the text. Do you have this kind of issues ?
    Thanks a lot, Tristan
  • TimvH
    TimvH - 2025-11-21
    Did you test this with the latest version of the CODESYS Visualization add-on?
    Something that you might want to test is if it works better when you disable the "Support client animation and overlay of native elements". Double-click on the VisualizationManager in your project to find this setting.
    • tristan - 2025-11-27
      Hello Tim, I am using CODESYS Visu V4.8.1.0. It works when I turn off the "Support client animation and overlay of native elements". But if I do that, dialog box moving and other options are also disabled so it is a bit problematic. Thank you for helping.
      πŸ‘
      1
      • thomasrek31 - 2 days ago
        Hello, have you found a solution? It seems I have the same problem as you. I can't remove the overlay, otherwise certain functions stop working
    Hello, have you found a solution? It seems I have the same problem as you. I can't remove the overlay, otherwise certain functions stop working.
