Lately I've been working in a project where visualizations are used extensively.
The target PLC is an embedded display/PLC all-in-one device.
I've got some strange behavior in the program (sure it's my fault) and I need to test it at the office.
As I can't connect to the usual target PLC I've copied the program and updated the device to Codesys Control Win V3 x64 but when I rebuild the project I am getting 502 errors coming from the libraries included.
i.e. The library 'element collections 3.5.17.0 was created with the unknown compiler version 3.5.15.20. Library CmpVisuHandler, 3.5.16.0 (System) has not been added to the library manager, or no valid license could be found. Library SysProcess, 3.5.16.0 (System) has not been added to the library manager, or no valid license could be found. Library SysShm, 3.5.16.0 (System) has not been added to the library manager, or no valid license could be found.
Won't I be able to test that program in my own computer?
Am I doing something wrong?
As always, thank you in advance.
Hello all,
i.e.
more posts ...
2 months ago I posted this and nobody answered.
The project is the same, how come libraries are a problem then?
Do I need a license to test the HMI in my own development PC?
Should I remove all libraries and start adding them from scratch?
How do you cope with this kind of problem?
Thank you all.
OK, just found out I can just set simulation mode on in my project and then VISU works flawlessly.
