Ethernet IP Scanner - L33ER CompactLogix Adapter discussion
Page 1.0 of 1.08
  • i-campbell
    i-campbell - 2020-03-19
    I offer you a warm welcome to the forge, sumitoccs!
    Is configuring AB CPLX as IO adapter a new thing? I know it wasn't possible a few years ago.
    I think the easiest would be to configure it the other way around (AB as master, CODESYS as slave).
    In future, try posing questions in forge.codesys.com/forge/talk/
  • sumitoccs - 2020-03-23
    Thank you so much for your warm welcome! I greatly appreciate it. Sorry for my delay response, I will definitely try posting this question under the link that you have shared with me.
    More than using it as an IO adapter we are trying to see if we can pass data with it, that will be compatible with other mapping structure that we have on other panels. Configuring the CODESYS as an adapter (slave) worked well and may be the path that we end up taking.
    Thanks again for your kind response!
