Ingo
Hardware
Prerequisites
Usage
Wirering
The chip has to be connected to a free SPI port. We assume, that you connect the chip with a chip select that coresponds to your SPI port. ATM we don't support to use general GPIOs for chip selects. Also no daisy chaining is supported, as the device doesn't support that.
This example shows the wirering of a MAX31855 with a Raspberry Pi Zero W, on SPI port 0 and chip select 0. This corresponds to "spidev0.0".
Add the device
  • Right click on SPI master
  • Add Device
  • Select the SPI Temperature
Configure the SPI port
  • Double Click on the SPI Master
  • Set the configuration parameters
Configure the device
  • Bitwidth
  • Resolution
Use the input values
