The chip has to be connected to a free SPI port. We assume, that you connect the chip with a chip select that coresponds to your SPI port. ATM we don't support to use general GPIOs for chip selects. Also no daisy chaining is supported, as the device doesn't support that.
This example shows the wiring of a MAX31855 with a Raspberry Pi Zero W, on SPI port 0 and chip select 0. This corresponds to "spidev0.0".
