BC9000 installtarget file???
Gulyware
2007-04-17
2007-06-14
  • Gulyware - 2007-04-17
    Did anybody used BC9000 from Beckhoff so far? I have a little project with that and there is no BC9000 in Target settings.I have TwinCat installed (from Beckhoff same as CodeSys 2.3 ) but this one is time limited. I was searching on the net if there is TNF or TRG file to install available...but Nothing I found.
    If someone has it share it with me PLEASE.
    THNX
    Gulyware
  • arj3090 - 2007-05-11
    I have used the BC9000 in multiple occasions.
    When you start a new project in TwinCAT PLC Control, select BC via AMS for ethernet comms. If you have the serial programming cable then slect BC via serial.
  • Gulyware - 2007-06-14
    arj3090 hat geschrieben:
    THX.
    But this one I knew already...I thought it's possible to use Codesys from 3S instead of the Twincat program.
    Anyway, I made the test with Twincat and was fine.
    Regards
    Gulyware
