I added a device "Ethernet" and then "Ethernet/IP Scanner" in device tree. After that I am trying to build the project, but getting error: C0041: VAR_IN_OUT parameter 'szComponent' of 'SysMemFreeData' needs variables with write access as input.
Can someone please help me in understand why I am getting this error and how to resolve it?
It is a blank project. I have just started using CoDeSys for Ethernet/IP controller, added only device "Ethernet/IP adapter" and build the project, got the compilation error. If you can explain what this error means? Image is attached, have a look.
if you post your project I can have a look at it. Can/t tell with the description only. Or at least post a screenshot.
