First time posting. Just had a general question. Wanted to see what ideas i could get for my code.
I have the following issue:
I have a pump that i install on my system with tubing x feet long that pulses out some liquid. When i start up my system i want to run the pump for x seconds to purge out air in the line. This is only done once. This means when i first install my pump, i purge out the air in the line for x seconds and never again even if my system is rebooted (memory retained). How would you guys approach this?
You time and effort is much apprecited
-J
PROGRAMTempratur_320_01VAR
  iINIT_Bac_alarm        : INT;    (*Sends values at startup, one time*)END_VARIFiINIT_Bac_alarm=0THEN(*EnablehighogLowitempfølere*)ZSK300E_320_001_RT401_PV.Limit_Enable.highLimitEnable    :=TRUE;(*Setalarmtextandtypeinbacnetvariable*)ZSK300E_320_001_RT401_PV_H_AL.Active_Text         :='Høy alarm';ZSK300E_320_001_RT401_PV_H_AL.Inactive_Text         :='Ikke alarm';ZSK300E_320_001_RT401_PV_H_AL.Notify_Type         :=Bacnet_alarm;iINIT_Bac_alarm :=+1;END_IF
On the first run iNIT_Bac_alarm variable is 0. And the IF sentence is true.
It goes true what should be set and last sets the iNIT_Bac_alarm variable to +1. Then it would not be true before it's set to 0 the next time it's reset.
Hope it helps
Espen
-J
Hello
I would do somthing like thise
Hope it helps
Espen
