Start contact
alverman
2017-05-24
2017-09-24
  • alverman - 2017-05-24
    Good morning,
    I would have a question for you:
    Is there a way to have a conception that opens and then closes when the program starts on the plc?
    In my project I have 4 OSCAT timers that at a certain time perform an operation only that every time the application loads on the plc the timers leave.
    I would like to create a denied contact that at startup interrupts the timer output to say 5 seconds and then closes.
    it's possible ?
    Thank you, Alberto
  • Anonymous - 2017-09-24
    I see you never received an answer. Hopefully you solved this. Otherwise my idea:
    Define another timer for 5 seconds and call it all the time.
    Β  Β BootDone : TON;
    Β END_VAR
    Β
    Β BootDone(IN:=TRUE, PT:=T#5S);
    Β IF BootDone.Q THEN
    Β  Β  //ok to use other timer values now
    Β END_IF
    Β
