Is there any setting which enables PLC XC201-EC512-8DI-6DO-XC to automatically store the values of some parameters as a text or other formats inside the PLC at interval? for instance sampling of parameters every six hours.
Tomasz is correct you have to do this yourself. Look at the SysLibFile.lib. You can save it to the MMC memory card I believe. I posted the library help here.
make a task every six hours and put the parameters into the markermemory
SysLibFile.pdf [79.72 KiB] (forum.codesys.com)
Does anyone have the Codesys SysLibFile.lib file to share?
