codesys 2.3.9.47 grayed out Target directories
B-Goetz
2019-04-11
2019-04-30
  • B-Goetz - 2019-04-11
    Using codesys 2.3.9.47, I am unable to enter locations for "Libraries" and "Configuration Files" located at PROJECT->OPTIONS->DIRECTORIES->TARGET as both fields are grayed out. Running Windows 7 PRO. Any help is much appreciated, thank you.
  • B-Goetz - 2019-04-15
    I have not received any responses to this post. I was told Edwin Schwellinger would be an great resource for help. Can anyone suggest how I may contact him?
  • Dave-76 - 2019-04-15
    This fields are allways grayed out, because they depend to the target, you have set in the Target Settings. Second pathes you can add in the field General or Project!
    eschwellinger - 2019-04-16
    you need probably to install the targets ( this is the part which comes from the plc manufacturer)
    Which plc are you using?
  • B-Goetz - 2019-04-30
    Using a Velocio PLC.
