At the attempt to make connection with C5-controller CoDeSys writes in window "Messages": . But at that time gives out the message . All adjustments are taken from Users Manual of C5-PCC, IP of the unit is also true... Please help us to solve this problem.
2005-08-30
Originally created by: DP
If I were you first of all I check connection PC<->PLC with ping. If connection is OK then make sure that CoDeSys runtime system is executed.
2005-09-06
Originally created by: V.Pupkin
DP hat geschrieben:
Thanks. Now is Ok. It was necessary to establish additional components and libraries Π‘5... I'm an idiot
Connection KEB C5-PCC (Programmable Communication Controller) with the CoDeSys via the Ethernet interface produced with the next settings:
