DELTA PLC AS228T
ramesh
2025-03-01
2025-03-09
  • ramesh - 2025-03-01
    I have Delta AS228T PLC. Is it possible to create a program in Structured Text using Codesys ?
    In other words, is DELTA AS228T PLC compatible with CODESYS ?
  • fgarcia - 2025-03-07
    You can create a program in ST for AS228T using either DELTA ISPSoft or DELTA DIADesigner.
    The only DELTA PLCs/Controllers I know of compatible with CODESYS are AX-3 and AX-8 series. You will need to install the proper packages, though.
    Cheers!
  • ramesh - 2025-03-09
    Thanks for your reply. Let me try with DIADesigner
