Weather Forcast Libary
2019-10-02
2020-08-30
  • chrisclarke11 - 2019-10-02
    I've been trying to set up the weather forecast library.
    I have Set and double-checked the country code and my API key but I keep getting an eError point to a Request_error.
    Has anybody come across this?
    Thanks in advance
    Chris
    eschwellinger - 2019-10-03
    I use it and it works since a long time...
  • chrisclarke11 - 2019-10-14
    Hi Edwin
    Did you have to set up any other HTTP or tcp parts or just use the function block
    Chris
    IMG: weather.jpg
    eschwellinger - 2019-10-14
    which plc is this and in which version?
    IMG: weather.png
  • chrisclarke11 - 2019-10-15
    Its a Lenze 3200C running version 3.16.1.0
    I was trying to do just a simple HTTP call on the plc yesterday in case there was any other setting that could be stopping it but was unable to get that to work either
    cheers
    Chris
    eschwellinger - 2019-10-15
    not sure which runtime system the 3200C is based,
    could you please check on plcshell
    rtsinfo
    We need at least CODESYS Control V3.5.10.0
    Just check that and its come back with RTS Version: 3.5.9.60
    Guessing that could be my problem then
    Cheers
    Chris
    yes I agree...
    Hi Edwin
    There isn't any archived version of the library anywhere is there that you'd know of?
    Chris
    no - not possible - guess the ssl encryption is missing in the runtime,
    therefore at least SP10 runtime is needed.
  • marsmännchen - 2020-08-30
    Hello, is it possible that it won't work with the PFC200 and 3.5SP16(and Compiler3.5.15.40)
    I´m getting an "request error" as well.
    Greetings
    Patrick
