Access to disk_sys
paulo
2011-12-20
2011-12-20
  • paulo - 2011-12-20
    Helo,
    I'm trying to access files from internal memory (create, open and write), but even using SysLibAsync I still getting watchdog timout when try to execute de open command.
    The code that I wrote for tests are below. Any idea of what I can do to avoid that watchdog exception?
    SYSFILE_OPEN : SysFileOpenAsync;
    SYSFILE_CLOSE : SysFileCloseAsync;
    SYSFILE_WRITE : SysFileWriteAsync;
    BUFFER : STRING := 'test';
    FILE : DWORD := 0;
    WRITEN : DWORD;
    ERROR : BOOL;
    ERRORID : WORD;
    ESTADO : INT := 0;
    PRONTO : BOOL;
    CASE ESTADO OF
    0: (Abrindo o arquivo)
    SYSFILE_OPEN(stFileName := '\My Documents\teste.txt', stMode := 'a', bEnable := TRUE, hFile => FILE, bError=> ERROR, wErrorID => ERRORID, bDone => PRONTO);
    IF PRONTO THEN
    ESTADO := 1;
    1: (Escrevendo no arquivo)
    SYSFILE_WRITE(hFile := FILE, pBuffer := ADR(BUFFER ), dwSize:= SIZEOF(BUFFER ), bError=> ERROR, wErrorID => ERRORID, dwWrite => WRITEN, bEnable := TRUE, bDone => PRONTO);
    IF PRONTO THEN
    ESTADO := 2;
    2: (Fechando o arquivo)
    SYSFILE_CLOSE(hFile := FILE, bEnable := TRUE, bDone => PRONTO);
    IF PRONTO THEN
    SYSFILE_OPEN(bEnable := FALSE);
    SYSFILE_WRITE(bEnable := FALSE);
    SYSFILE_CLOSE(bEnable := FALSE);
    ESTADO := 0;
    ELSE
    ESTADO := 0;
    END_CASE
  • singleton - 2011-12-20
    try to execute read/write operations in a separate low priority task with enough cycletime.
    SysFileOpen can take up to 100ms and SysFileWrite can take several 100ms.
    That should be the source of your watchdog
