The webvisu on the WAGO PFC200 shows users are deactivated when accessing user management, however they are active actually. Tried deleting user management and re-creating and uploading a good user management profile, no matter what, it always shows deactivated in the web visu. Any ideas what is causing this? It works on another controller I have, just this one has the problem. This is the Codesys 3.5 SP14 with WAGO FW9 (since EtherCAT Master does not seem to work on newer FW's)
Thanks you
Works fine in Codesys IDE using same visu menu.
please send the project to the CODESYS store helpdesk
store.codesys.com -> my question -> bugreport
According Ethercat,
i'm pretty it works, I have two devices which are running Ethercat with current Wago Firmware ( guess this is FW 11)
(As I remember there was a problem on older FW but not sure which version it was exactly)
for the red cross - could you please check if the images are downloaded to the visu directory ( browse them by the CODESYS file browse)
I assume either they are not on the device or the memory is maybe full ( check with df on Linux)
(You could check the browser console and check the messages there additional check the plc logger)
Thanks you
According Ethercat,
