hardware for agriculture application and codesys
tdie
2019-10-24
2019-10-27
  • tdie - 2019-10-24
    Does anyone has experience with hardware which can stand up the harsh environments of agriculture and codesys?
    We are using a industrial grade PLC now which is based on Codesys but it's not good enough for the environment.
    If yes, which are you using?
  • Anonymous - 2019-10-24
    Beijer x2 extreme.
  • Maximilian-K - 2019-10-26
    https://crosscontrol.com/?
    We use them for marine an they work great.
    For IO ifm CR203X or CR205X series are good. ifm also has controllers but I believe they are all still on CoDeSys 2.3. https://www.ifm.com/
  • i-campbell
    i-campbell - 2019-10-26
    I know IFMs ecomats can use V3.5 like the CR711S.
  • dkugler - 2019-10-27
    Originally created by: D. Kugler
    Berghof Automation manufactores a heavy duty display controller for V3.5 with IP67 for agriculture, mining, offshore, marine:
    https://www.berghof-automation.com/en/i ... riculture/ m
