lefish - 2022-03-17
Hello everyone,
I am having troubles to get the IO-Link Bus working again after switching from an EL6224-Card to a EJ6224 module.
In both cases I worked with the very same sensor, an ifm OGD580 distance sensor.
I purchased the IO-Link-Master license.
This is the state with the EJ6224 module:
And this is the sensor view:
I double checked the wiring. The Sensor does show a reasonable value on its display.
Interestingly I do get an Int-Value fΓΌr very small distances (<3 cm) which is the same as the distance shown on the display (2 or 3 cm)
But if I increase the distance the value on the bus changes to 1 and stays.
I also get values for the device state ("OutOfSpec", "OK" etc.)
If I read the device parameters of the sensor (F/W-Version, S/N, etc.) , I get reasonable values as well.
Thanks for your help!
Best regards
LeFish
Last edit: lefish 2022-03-17
