I am newbie here, In my Project I am using CoDeSys Runtime whihch running in raspberry pi.
One of the Ethernet Post has been configured as EIP Adapter and other one as a EIP Scanner.
The One which has been configured as a EIP Adapter getting into exception state at a regular interval.
Unable to identify the Root-Cause of this Issue.
Any help in fixing this highly appreciated.
Attaching the Exception image for your ready reference.
check if you are up to date with your EIP version. If a newer version is available install it and then update the project by richtclick on the EIP scanner - update device
(current version is 4.3.0.0)
Last edit: eschwellinger 2022-09-14
Again got into an exception State, and found it's due to the Scanner. it's related to communication time-out.
Please refer to the attached files and do suggest me the right action to take.
Hi Everyone,
I am still, getting the Exception even after disabling the watchdog.
In my Project, I have configured the EIP hardware tasks in Cyclic mode,
Is this could be a reason for these Exception?
Is it better to configure the hardware in Freewheeling type?
Your valuable input highly appreciable.
Best regards,
Mani
Got same problem, appeared after 4.3.1.0 update.
Prabably problem is in performance. I am using virtual machine, so adding one more core and several GB to RAM still not solved, but atleast did system more stable.
Try optimise your main program or set less task interval.
Regards,
I will be your mate in solving this mistery =)
Best regards,
Mani
thanks for your input, I have updated and kept the system under observation. Wil update you if i face any challenges.
Thanks Again.
-Mani
Can anyone help me in resolving this issue, keep getting this exception at a regular interval.
https://forge.codesys.com/forge/talk/Engineering/thread/1482db316b/4b84/attachment/Unconfirmed%20192879.crdownload
Best Regards,
Mani
Hi Everyone,
Best regards,
Mani
Regards,
