Safety Editor
2022-09-22
2022-09-30
  • yannickasselin - 2022-09-22
    2 questions:
    1 - Is it possible to manually connect a line between 2 FB? If I drag a FB on the output of another FB, it will automatically connect it to the first input. But if I want it connected to the second input, I cannot find a way to move the yellow line.
    2 - How can I connect 2 FB on 2 different network (rung)? I know I can explicitly write the name and of the FB in the input of the other FB, but if I have nothing connected to the output of the first FB, it will not build.
  • yannickasselin - 2022-09-26
    Am I the only one using the Safety Editor?
  • yannickasselin - 2022-09-28
    No one? Anyone?
    eschwellinger - 2022-09-28
    give us some time ..
    Ok, thanks
  • fhumbeil
    fhumbeil - 2022-09-30
    1 - Is it possible to manually connect a line between 2 FB? If I drag an FB on the output of another FB, it will automatically connect it to the first input. But if I want it connected to the second input, I cannot find a way to move the yellow line.
    No, this is not possible. You can instead split your Network 1 into two, like in the following image:
    You can connect it as shown in the image above. There are no compile errors, if the output of FB_OR_1 is not connected to an output.
  • yannickasselin - 2022-09-30
    I am sure the last time I tried it was not working, but I tried it again today and it works. I must have done something wrong the last time.
    Thank you.
