I am working with 'Codesys Control For Raspberry Pi'(v 4.9.0.0) and I am facing a very strange issue-
I am unable to create a text file. I am getting an error -"FILE_OPERATION_DENIED"(5114) during File Open.
I am able to create a .txt file manually in the same location. I also tried giving the entire folder full read, write and modify access to all the users using - sudo chmod (my_file_path) a+rwx. Yet, still I am getting the same error. The Recipe Manager that was working fine in my previous device is also not running now.
Best Regards,
Suyash Thatte
Ok, I just changed the FILE.OPEN path to "/var/opt/codesys/PLClogic/" still getting the same error. Also, I manually tried creating both a file and directory inside the above location, I am not able to create it.
Please correct me if there is an understanding gap.
Nope!
The file path is $$PlcLogic$$ and NOT $$PLCLogic$$.
Otherwise a new folder ('PLCLogic') is created (at least with a linux rt - like raspberry or compute module) with the new file in it if you open the file with eFileMode := FILE.MODE.MRDWR.
That is a bad bug that I'll report right after this comment.
@eschwellinger Thanks a lot for your help.
However I am unable to understand the root cause behind the failure. The directory that I was writing the file to had rwx access to all users and groups. I had also tried creating and modifying a text file using python which was successful. Why is it failing with Codesys runtime?
Regards,
Suyash
@eschwellinger does FILE.Copy fails with FILE_OPERATION_DENIED when copying outside from the IEC path for the same reason? I'm looking for a workaround to this limitation.
Dear all,
Best Regards,
Suyash Thatte
use the PLClogic directory to read / write files.
/var/opt/codesys/PlcLogic
this is due security reasons forced to use.
Last edit: eschwellinger 2025-03-04
the file path in IEC is $$PLCLogic$$ instead of /var/opt/codesys/PlcLogic
Nope!
Regards,
Suyash
because of security reason it is not allowed anymore to access files outside the IEC accsible path.
Found it! Set ForceIecFilePath to 0 in CODESYSControl.cfg
