Profinet RTE Control SL Build Errors
ap040
2020-08-10
2020-08-26
  • ap040 - 2020-08-10
    I downloaded and installed "CODESYS Control RTE V3". Before that I used CODESYS Control Win SL which is not supported the Real Time operation.
    When I build the program using the Control RTE V3, it has given the list of errors. Can someone help on this?. I already installed library package which is available with the setup file "CODESYS Control RTE SL 3.5.16.package".
    Attached the errors snapshot.
  • ap040 - 2020-08-25
    Hello @eschwellinger,
    I tried to update the driver on my Ethernet adapter but it has crash my PC. I checked with β€˜CmpEt100Drv’ and β€˜CmpEt1000Drv’ drivers. Currently, Realtek PCIe GBE Family Controller driver is installed on my PC.
    Go to Device Manager -> Network -> Realtek PCIe GBE Family Controller -> Right click -> Update driver software -> Browse my computer for driver software -> Let me pick from a list of devices... -> Have disk -> Browse and select the .inf file from the CODESYS folder.
    Please do needful help. What is the wrong step here?.
    Last edit: ap040 2020-08-25
    • i-campbell
      i-campbell - 2020-08-25
      CmpRTL8169Mpd is the one for Realtek Gigagbit Ethernet.
      You will need to disable secure boot, as CODESYS don't get Microsoft to sign their drivers.
    Yes, I already done it and without crashing the PC, it has installed.
    @eschwellinger, I have facing same problem while the building the project.
    Can you please help, how we can get the compatible Ethernet library which can solve the errors?.
    eschwellinger - 2020-08-25
    Did you add the networtdriver component to the RTE configuration?
    Is your CODESYS SP16Patch1 too?
    No additional libs are needed - everything ist included in the CODESYS Installation
    Last edit: eschwellinger 2020-08-25
    @echwellinger, Thank you for your so far support...!!
    How I add network driver components?. Can you please share some details about this?.
    Add CmpRTL8169Mpd by righclik in the tasktray RTE components list or add it to the configuration file...
  • ap040 - 2020-08-26
    Hello @eschwellinger, I configured the CmpRTL8169Mpd component from the PLC configuration option. However, errors are still same. What else I need to do it?.
    In my PC the CODESYS installed version is 3.5.16 - Release date 5.5.2020
    Last edit: ap040 2020-08-26
    I installed the latest release of CODESYS and it is working without any errors.
    Thank you!!! @eschwellinger.
