Problem with MCP2515 and library CANbus
chrismel
2021-11-25
2025-03-27
  • chrismel - 2021-11-25
    Hi guys,
    I'm starting a project with a raspberry pi and MCP2515 CAN-module.
    I've implemented code to open and send message to "can0" and apparently it work.
    However, when I try to send more then 10 messages each 100ms, the module block all trasmission.
    I've noticed CL2.CreateMessage(...., ....) return the error message "30112" I believe it is "queue error".
    After that I tried to change the "txqueuelen" of the device using the command "ifconfig can0 txqueuelen 10000"
    but the issue it's the same.
    I can send little more than 20 messages for a few minutes before I generate the same error.
    How do I transmit hundred messages on the CAN?
    Should I change other settings on the raspberry?
    I append the code I made to send messages.
    Let me know if you have any advice to give me to make it work.
    Thank you.
  • czek - 2025-03-27
    I encountered this same error. I was able to resolve it by allocating more messages when I open the network driver (ctMessages:= 100). By default it is set to 25.
