How do I pass a array throught a function and return an array - Pointers
Volvo742
2018-04-16
2018-04-16
  • Volvo742 - 2018-04-16
    Hi!
    I want to pass a array of strings throught a function and that function is going to return back the array. So I need to use pointers for that.
    Let's keep it simple!
    I first have my array:
    myStrArray: ARRAY[0..10] OF STRING;
    Then I need to convert myStrArray to a pointer.
    p_myStrArray: POINTER := ADR(myStrArray);
    Then I need to pass p_myStrArray throught my function
    p_returnArray := myFunc(p_myStrArray);
    FUNCTION myFunc: POINTER
    VAR_INPUT
    Β  Β p_myStrArray: POINTER;
    myFunc := p_myStrArray; // Return statement
    And then recive my pointer and turn it back to an array
    returnArray: ARRAY[0..10] OF STRING;
    returnArray := p_returnArray^;
    But it won't work for me. What have I missed?
  • josepmariarams - 2018-04-16
    Wrap your array with an fb and pass the fb to the funtion as varinout. Or better, the funtion could be an method of the fb.
    If not, you don t know from inside the funtion array dimension.
  • Anonymous - 2018-04-16
    Originally created by: rickj
    I didn't know the compiler would allow this
    VAR_INPUT
    Maybe try this instead
    FUNCTION myFunc: POINTERΒ  ARRAY[0..10] OF STRING
    VAR_INPUT
    Β  Β p_myStrArray: POINTERΒ  ARRAY[0..10] OF STRING;
    END_VAR[/quote]
    Then when you call the function you may try this
    Β  Β  MyStrArray: ARRAY[0..10] OF STRING;
    Β  Β  PtrReturnArray : POINTER TO ARRAY[0..10] OF STRING;
    PtrReturnArray := myFunc(ADR(MyStrArray));
