External File
nmm
2017-08-03
2017-08-04
  • nmm - 2017-08-03
    Can anyone please explain the purpose of external file in CoDeSys3.
    Can we use this file to pass parameters to the project for configration.
    eschwellinger - 2017-08-04
    For examle you could download pdf files to the plc and show them in the visualisation or if it is a pc based control
    Show them on your target.
    Sure maybe if you download inifiles you could read them for examle by inifile reader ..
  • nmm - 2017-08-04
    Hi Edwin,
    Thanks for your reply.
    I am trying to download a csv file with some values and trying to read them in CoDeSys using SysFileRead but can't read the file.
    1. First issue is that I am not sure if the file is really downloaded onto the PLC as there is no indication
    2. Second issue is if it is downloaded what's the location/path of file?
    which plc are you using (it depends on the runtime version too)
    You could check with the CODESYS file browser,
    the file will be downloaded runtime Directory /Plclogic/Application
    IMG: externalfile.jpg
