How to get MAC-address?
Mouse
2012-01-20
2012-01-30
  • Mouse - 2012-01-20
    Hello!
    There is the function "getadapterinfo" in CmpSysEthernet.library. I try to use it to get MAC of local Ethernet adapter. But i can't understand what it gets me. The field MAC, which the function returns, doesn't match the real MAC of any adapter in my PC. Unfortunately I can't find extra information of this function.
    Is some other function (way) there, which can get MAC address?
  • Rolf-Geisler - 2012-01-20
    Windows-system?
    If yes
    ==> start menu "Run"
    Enter "cmd" + Return
    "ipconfig" will return the IP and MAC addresses of all present network adapters.
  • Mouse - 2012-01-22
    Thank's, but i need to get MAC in IEC-task for different system. Now i get it by outer ARP request and send the result back to IEC-task. But it's inconvenient way, and it doesn't work behind router (router changes PLCs MAC on its own). i need something local and universal to get MAC in IEC-code.
    eschwellinger - 2012-01-30
    1. you need to add/check if a component is in your runtime:
    Component.x=SysEthernet
    (runtime config)
    1. use the following snippet:
    declare:
    diNumber: DINT;
    iAdapter: DINT;
    stName: STRING(255);
    stDescription: STRING(255);
    aby_address:ARRAY[1..6]OF BYTE;
    program:
    getnumberofadapters(ADR(diNumber));
    FOR iAdapter := 0 TO diNumber DO
    getadapterinfo(
    iAdapterNum := iAdapter,
    pbName := ADR(stName),
    pbDescrition := ADR(stDescription),
    iBuffersize := SIZEOF(stName),
    iMacLength := 6,
    sMacAdress := ADR(aby_address));
    END_FOR
    cu
