Hello, I am currently doing a project with profinet IO-link master device and I cant plug in IODD device file. When I try to run with Ethercat IO-link master device the IODD device shows up and I am able to plug it in. What is wrong here? Does PROFINET support the IODD files ? Is it a problem specifically in the IO-link master that it does not support the IODD compatibility ?
Hello, we have the same problem here.
Our configuration in the following:
Codesys V3.5 SP19 running on Exor Exware700Q
Profinet network connected on Eth1
IOLink Master Turck TBEN-S2-4IOL version 3.5.9.0
IOLink sensors E+H & Sick (Pressure, TΒ°)
We installed the codesys IO link package and have the codesys IO Link SL licence activated (on a dongle)
Our problem is the following:
we got the IODD files from E+H & Sick
we add the devices in the codesys device repository with success
They appear in the devices tree under IODD branch
We added the TBEN IOLink master under the Profinet IO .
The IO link master are ok and display online.
The IO-Link SL package datasheet indicate that there would be a way to scan the IOLink device from the network but we did not find any way to trigger this scan. (we expect to get this from a right click on each IO-Link Master module but the only possibility there is "Plug device")
When clicking on Plug Device, we get a browse window with profinet IO modules. The IODD devices are not there so we cannot select them. But other devices for other brands are available and can be plugged.Our question are : 1) how do we update the Profinet IO Module catalogue in order to be able to plug the E+H & Sick Sensors that we have to work with?
2) how do we activate the Scan IOLlink device that is supposed to be included in the Codesys IO-link package?
3) where can we find the manual explaining how to use this package?
I am having the same problem right now. Could you please share more information if you were able to solve the problem?
Some IO-link master are configured from a webserver. Then they expose a communication table you can define on it (MURR works this way).
Last edit: pruwetbe 2024-11-12
