I need to log into a Codesys 3.5 PLC via CANbus (CR711S). The manufacturer is ifm Electronic GmbH. The release notes state that it is possible to do so, but a PCAN-USB adapter must be used for stable connection. It also says that the CAN client must be added to the Codesys gateway configuration as a top level interface.
I have a PCAN-USB adapter, and from what I can see in my Windows device manager, the service for the adapter is 'PEAK_USB'. I have added this as a CAN client to my gateway configuration as a top level interface.
At this point I expected to see CAN as an option when adding a gateway for communication, but instead I only have the default TCP/IP on port 1217 available.
Could anyone help with this?
Thanks in advance!
Best regards,
John
Hi John,
i would expect that IFM has a good description for doing this with their PLC.
If think you need to uncomment the following lines in:
c:\ProgramData\CODESYS\CODESYSGatewayV3\18061919\Gateway.cfg
[ComponentManager]
;--> Additional components for CmpBlkDrvCanClient
Component.1=CmpBlkDrvCANClient
Component.2=CmpCAASdoClient
Component.3=CmpCAACanL2
Component.4=CmpPCANBasicDrv
;Component.5=CmpCANFoxDrv
;Component.6=CmpIxxatCANDrv
;<-- Additional components for CmpBlkDrvCanClient
;--> Additional components for CmpBlkDrvUsb
;Component.6=CmpUsbMpdUsbLib
;<-- Additional components for CmpBlkDrvUsb
[CmpBlkDrvCanClient]
CycleTimeMs=1
NumChannels=1 ; Number of block driver instances
0.Name=BlkDrvCanClient
0.NetId=0 ; CANbus Network Id (0..n)
0.Baudrate=1000 ; CANbus Baudrate in kbit/s
0.NodeId=1 ; unique NodeId
0.BlockTransfer=1 ; Use block transfer for more performance
[CmpCAASdoClient]
MaxSegmentsPerCycle=0 ; for block download: maximum of sent segments per cycle; 0 means infinity
π
1
Hi All,
Thanks in advance!
Best regards,
John
Hi John,
[ComponentManager]
CycleTimeMs=1
[CmpCAASdoClient]
