Hello, I am currently facing an error while trying to download and update libraries through Package Manager. I am using CODESYS V3.5.18.20. When I select and start the installation of the libraries it throws me an error attached to this issue bellow. However when I abort the installation and start again it does not throw the error again. But the whole instalation of CODESYS is corrupted. How do I fix this problem please ?
I had also a quite similar error today when trying to update packe with the codesys installer 1.4.0.
Is there a solution? Tried to repair codesys V3.5 SP18 Patch 2 several times even installed it from beginning on another computer, had the same issue. Please provide a solution!
Repairing did not work either. I allways need to uninstall and try again. Only thing that worked for me was installing the packages solo by their separate instalators. Codesys installer cant install it properly and allways throws these errors and then the CODESYS installation is corrupted again...
@pilgrim - maybe you could try to install the package by its separate installer, you can download the package on codesys store
Last edit: vformanek 2022-08-17
Repairing the codesys installation could probably work.
Could you please do this:
https://faq.codesys.com/display/CDSFAQ/CODESYS+Installer+logs
check the Event viewer for errors then - if there are problems with the CODESYS Installer
Last edit: eschwellinger 2022-08-17
@eschwellinger - Im going to try the event viewer
Last edit: vformanek 2022-08-18
Okay guys I think it is working.. Still needs to be tested but when I reinstalled CODESYS here are the steps I have done:
Please try this aproach and keep me posted !
