SysProcessExecuteCommand2.project
tomas111
2023-02-07
2023-04-05
  • tomas111 - 2023-02-07
    Faced with such a problem that this project does not work on target 4.5.0.0 and new versions of Raspberry Pi OS. In the CODESYSControl_User.cfg file, I inserted
    [SysProcess] Command=AllowAll
    Confuses the path that is in the example:
    command1 : STRING := '/opt/vc/bin/vcgencmd measure_temp';
    command2 : STRING := 'cat /proc/cpuinfo';
    Last edit: tomas111 2023-02-07
    eschwellinger - 2023-02-08
    add the following entry in /etc/CODESYSControl_Usr.cfg
    [SysMem]
    Linux.Memlock=0
    Last edit: eschwellinger 2023-02-08
  • tomas111 - 2023-02-08
    I did, the result is the same. Does not work...
    Is it really latest runtime 4.7.0.0?
    • tomas111 - 2023-04-05
      Installed version 4.7.0.0. This option does not work unfortunately. Maybe there are other options?
    4.5.0.0 Do you need 4.7.0.0?
    Last edit: tomas111 2023-02-08
