OPCClient
wouter
2008-01-24
2009-04-13
  • wouter - 2008-01-24
    I am absolutely new to OPC so if anyone could help me with this i would be very happy:
    I want to write a C++ client application that monitors some variables from a project running on a softPLC (under windows xp). As far as i understood from documentation OPC is the solution for this.
    I get the OPC server running but can anyone tell me how i can communicate with the OPC server now from my client application??
    Someone maybe has an example in C++?
    thanks a lot in advance!
    wouter
  • golgon - 2009-04-13
    You can connect opc server to your program by using PLCHandler.
    This PLCHandler can be used in c or in vb.If you want to use in vb,you can
    use .ocx file.If you want to use with c,you can use dll file.
    w www.izabil.com w
