CSVReaderInit returns error : INVALID_HANDLE
totorovic
2023-06-26
2025-11-26
  • totorovic - 2023-06-26
    Codesys IDE is 3.5.17.21
    Sometimes the bloc CSVReaderInit from the library CSVUtility (1.0.0.5) returns the following error : INVALID_HANDLE.
    How can I get more informations about the meaning of this error ?
    Thx you
    Last edit: totorovic 2023-06-27
    eschwellinger - 2023-06-26
    which runtime & version are you using?
  • totorovic - 2023-06-27
    Runtime is CODESYS Softmotion RTE x64 version 3.5.15.30
  • totorovic - 2023-06-28
    Do you have news about this error ?
    Error does not happens everytime but randomly. Error cannot be acquitted. Codesys runtime has to restart to clear the error. After restart, it works again.
    eschwellinger - 2023-06-28
    this is not a known, which version of csvreader is it?
    Possible that you are using not latest version?
  • totorovic - 2023-07-17
    Please, how can I get more informations about the meaning of this error ?
  • totorovic - 2023-07-20
    We installed IIoT libraries (and upgrade csv_utility to newest version).
    Now we get error message with licence.
  • mozed - 2023-07-20
    same problem here
    Last edit: mozed 2023-07-20
  • daniel - 2023-08-15
    Hello, is there already a solution for this problem (invalid handle)? 3 month ago the librarie work without problems...
  • totorovic - 2023-08-21
    Actually no solution. We are waiting Codesys reply.
    Latest version of library : licence error message
    Version 1.0.0.5 : INVALID_HANDLE error message
  • totorovic - 2023-08-28
    Can we please have some details about the error : INVALID_HANDLE?
    So we can try to avoid it.
  • roundex - 2023-08-30
    I got same issue but managed to get it to work again by downgrading the Runtime.
    Here's my specs:
    CODESYS V3.5.19.0
    Runtime Linux SL 4.7.0.0.
    CSV Utility SL 1.1.0.0 (Licensed IIoT libraries SL)
    I tried Runtime 4.8.0.0. and 4.9.0.0 but both result in INVALID_HANDLE error.
    Last edit: roundex 2023-08-30
    eschwellinger - 2023-08-30
    this is a security issue not to read/write in the plc allowed path I would recommend to update and change the path in the application were the files are😏
    πŸ‘
    1
    Last edit: eschwellinger 2023-08-30
    Could you please give me an example where to select new path in plc. Right now my csv files are placed into /home/user/csvfiles
  • totorovic - 2023-08-31
    Thank you for the return. The path targets to a CFast card. User has R/W access to it. We will try to change it.
  • totorovic - 2023-10-27
    We changed the path where the CSV file is. From intern memory of the IPC to a USB key.
    We still have this error 'INVALID_HANDLE'. We must restart the Codesys runtime to clear it. That is a big problem for us because machine is in production.
    @eschwellinger What do you mean by "this is a security issue not to read/write in the plc allowed path"
  • youness - 2025-11-26
    I have Already the same problem when i'm trying to write data more than 10 times in the same file. In fact, i send my data periodicaly to a file that i configured to have permission of W/R in my CodesysContol.cfg. When the Error occurs, i must reboot my machine to success. It means that the problem isn't realted to a limitation of size, but a problem in the function supposed to handle the file.
    totorovic : allow me to know if you've found a solution to your problem.
    Thanks.
