hope to have understood correctly (sorry for my poor English): you run an OPC server on your system, used as a data gateway, and additionally you have a CoDeSys PLC.
If you want your OPC server to have access to CoDeSys, I think this needs an (internal) OPC client, connected to a CoDeSys OPC server to read and write CoDeSys information.
Have success
Because I have all data defined in my own OPC Server, which reads and writes to hardware device,
So I expect Codesys be able to browse my OPC Server, get the I/O points for the configuration. In fact it's mentioned in V3.2 help with function as Add Data Resource. But when I try that, it shows "OPC Server, not yet implemented." Any idea when it will be available ?
Thank you.
This topic seems still to be unanswered. I have a similar need. I have a non-CoDeSys PLC with its own OPC server "X". I would like to use CoDeSys OPC Server to aggregate the items in server X. This would simplify my OPC client configuration. So, can I do this with CoDeSys OPC Server?
BR,
Jukka Peltola
I'm pretty new with CoDeSys.
In our system, we have a data gateway running as an OPC Server on Windows XP Embedded.
My question is if CoDeSys can Read/Write to my OPC Server as I/O.
I tried the latest V3.2, in the help of add data source, says "not yet implemented". Your help is appreciated very much.
Have success
thanks.
What I really want to have is:
Thank you.
BR,
Jukka Peltola
No, this is not possible. Just connect your client to the other server.
