My code has a reproducible case of infinite loop, but it only happens when running without any breakpoints.
The observed behavior is the freewheeling task is not finishing.
Debugging by setting breakpoints "fixes" this behavior. When I press "STOP" the application stops.
I couldn't find any way to debug this - show me where the freewheeling task was executing before stop.
Is there any way to break at the infinite loop (which I don't know where it's located in the code...)
Did you try to define a watchdog for the task? Usually an expired watchdog should show you the endless loop: https://www.youtube.com/watch?v=Aeihipp6U4I
