Persistence Manager Backup
matthew
2023-10-18
2024-05-14
  • matthew - 2023-10-18
    Is there a process to restore Persistence Manager files? I have backups of persistence variables used in a machine that is currently operating and tuned and all set points adjusted. There are about 500 persistence variables, they are building another identical machine. I would like to use Persistence Manager files from the first machine in the second also.
    I have tried copying the files and replacing them on the new RPI but then the Persistence Manager gets errors and then they are all reset to 0 etc I have tried adjusting the times to match. Instead of replacing whole file, I tried just changing the contents inside the file, but still does not work. I may be missing something here, but surely there must be a way to load a backup.
    Thanks!
    eschwellinger - 2023-10-19
    you need at them moment a download once (for the configuration files generated including addresses)
    then stop the plc - exchange the persistence file ( without the config file)
    This will be improved to 3.5.18.6 and 3.5.20.0. (possible then to generate offline bootproject including full persistenmanager files) - this is if you have not 100% the same bootapplication on the devices.
    In case you copy the whole Application (PLCLogic) directory it should work out of the box - but only with 100% same bootprojects as mentioned above.
    By the CODESYS Automation Server would help solve this too.
    Last edit: eschwellinger 2023-10-19
  • matthew - 2024-04-23
    Hi @eschwellinger How does the persistent manager files work on v20? I would Like to upgrade my v19 as I'm still having issues. Sometimes if there is a power cut CodeSys won't load the Persistence Manager files and I have to redownload to the PLC and then copy my backup persistent files and then start the application. I hope it's a lot more robust in v20
    eschwellinger - 2024-04-23
    Last edit: eschwellinger 2024-04-23
    • matthew - 2024-05-14
      Hi @eschwellinger yes I have been using xDoubleStorage It happened again and I checked and the files were still there with there contents, restarting codesys or rebooting would not even reload them. Doing a download and then starting the PLC loaded them and began working again. Some sort of mismatch error or something?
