Is it possible to add regions to ST-code?
Kim
2016-08-22
2025-07-10
  • Kim - 2016-08-22
    In order to structure my ST-code I sometimes would like to be able to collapse/expand parts of the code to my own liking.
    For example, in C# you can use #region and #endregion to create your own "folds".
    Does something similar exist in Codesys? I've searched the built-in help and forums but came up empty.
    As of now, my workaround is to put my code within dummy IF-statements which then can be collapsed separately.
  • r.evbatyrov - 2016-08-22
    Hi Kim,
    yes, it is possible since CODESYS V3.5 SP9 with the following syntax
    {region "Description"}
    // code
    Regards
    Roman
    • hermsen
      hermsen - 2023-06-27
      // code
      // code
      {endregion}
