Is there a way to get a string which is the name of the variable passed in parameter of a function ?
I test the type ANY (__System.AnyType) which provides 3 fields (pointer to the value, value size and type class) but not the name of the value.
For example :
FUNCTIONfuncVAR_INPUTÂ Â info:ANY;END_VARVARÂ Â infoSize:DINT;Â Â infoTYPE:__SYSTEM.TYPE_CLASS;Â Â infoPointer:POINTERTOBYTE;Â Â infoName:STRING;END_VARinfoSize:=info.diSize;infoTYPE:=info.TypeClass;infoPointer:=info.pValue;infoName:=""//???????????????????????
func(GVL.myVar);
Now, I would like to retrieve, in my function func, the name of the variable "GVL.myVar".
I heard about __VARINFO, however I can't find a easy way to retrieve such an information.
Please help
Regards,
FG
2016-09-07
Originally created by: flogir
The attribute 'parameterstringof' is only available in visu, it's to bad because it whould have solved the problem....
FUNCTIONfuncVAR_INPUTÂ Â info:ANY;END_VARVARÂ Â infoSize:DINT;Â Â infoTYPE:__SYSTEM.TYPE_CLASS;Â Â infoPointer:POINTERTOBYTE;Â Â {attribute'parameterstringof':='info'}Â Â infoName:STRING;END_VARinfoSize:=info.diSize;infoTYPE:=info.TypeClass;infoPointer:=info.pValue;
For example :
Please help
Regards,
FG
See this post
l viewtopic.php?p=14404#p14404 l
Varinfo gives to you class name and instance name.
