Can't connect with Beckhoff
apakrat
2018-12-28
2019-01-14
  • apakrat - 2018-12-28
    Hi guys, i have some problems when i try to connect my Beijer HMI X2 control with Ek1100 and it's module via etherCAT. I've read some instruction between Ras Pi and Beckhoff and followed them but nothing change. Anyone have any ideas please tell me. Thank you so much!
    IMG: Untitled.png
    eschwellinger - 2018-12-28
    could you give us a screenshot of the plc logger?
  • apakrat - 2019-01-03
    What is the PLC logger?
  • Anonymous - 2019-01-03
    Hello
    1. Which build are you using in the X2 Control?
    2. Do you remember if you selected 'Yes' or 'No' to the DC (distributed clock) question when you installed the Codesys PLC?
    3. Have you referenced the correct library versions? Beijer use version 3.5.10.10
    4. If you are able to post your code, I can look.
    ph0010421
  • apakrat - 2019-01-04
    Hi ph0010421,
    I don't understand your 1 question, sorry I'm new with beijer.
    I can't remember because I installed long time ago.
    I think it right, I can connect codesys with beijer, I've tested it, when I changed tag value in laptop with codesys the tag value in the panel changed too.
    I didn't write any code in this project, I want to check the connect first
    eschwellinger - 2019-01-04
    IMG: PLCLogger.png
    Hi Edwin, i didn't think there are a lot of error like this. ph0010421 is right, maybe my library have some problem.
    IMG: Untitled.png
    did you set/browse the correct network interface which is connected to your slaves?
    IMG: BrowseMAC.png
  • Anonymous - 2019-01-04
    I agree with Edwin.
    Browse for the network adapter.
    If you did NOT select DC then it's called ENET1.
    This relates to the physical LAN A port.
  • apakrat - 2019-01-05
    Hi, I already use browse to pick X2 Ethercat (lan A).
  • Anonymous - 2019-01-05
    Which version IDE are you using?
  • apakrat - 2019-01-07
    I use CODESYS V3.5 SP13 Patch 1 and iX Developer 2.40 SP1 for panel.
  • Anonymous - 2019-01-07
    apakrat hat geschrieben:
    Ok. Which libraries has it used? It will default to use the latest and this is not what we want.
    The compiler needs to be set to 3.5.10.10 and all libraries need to be 3.5.10.10 or earlier.
    As I said earlier, if you post your project, I can have a look for you.
    Kind regards,
    ph
  • apakrat - 2019-01-08
    ph0010421 hat geschrieben:
    Kind regards,
    ph
    Hi ph0010421, here my project. If you can fix it for me, i'll very appreciate it.
    And like you said, I updated the libraries to some new version not 3.5.10.10. I'll try to edit it.
    Thanks for you help!
    beijer.rar [233.74 KiB]
  • Anonymous - 2019-01-08
    Please can you SaveAs 3.5.10.10
    Hello
    You need to install 3.5.10.10 to get the necessary libraries.
    1. Compiler version should be set to 3.5.10.10 (Project-->Project Settings)
    2. Remove Visu references (not supported) and all the libs it brings in.
    3. The EtherCAT task has got confused. Delete the EtherCAT task then Delete the Master, then 'Add Device' and add a 3.5.10.10 EtherCAT master. Don't try and manually add an EtherCAT task; it does it automatically. See screen shot.
    1. Select NIC by network name rather than MAC ID
    Regards
    Paul
    IMG: Capture.PNG
  • apakrat - 2019-01-11
    Hi ph0010421, I used to try convert it to 3.5.10.10 but it not work, the library is still the latest. I followed your step when add EtherCAT master but I don't know why he still outside the Maintask .
    Here some file I save as 3.5.10.10. Sorry about late reply, I've been busy so far.
    Btw, thanks for youe help, I very appreciate it.
    Save_as_1010.rar [200.07 KiB]
  • Anonymous - 2019-01-11
    You hadn't made any of the changes I suggested, so I guess you didn't install 3.5.10.10 either?
    Attached is a .project. If you didn't install 3.5.10.10 it will be missing libraries, but these can be downloaded with the 'Download Missing Library' button in the library manager.
    I don't have the Beckhoff Device descriptions, so add these devices to the EtherCAT master manually.
    ph
    beckhoff_beijer.project [153.21 KiB]
  • apakrat - 2019-01-12
    I've installed v3.5.10.10 but everything didn't change.
    IMG: Untitled.png
  • Anonymous - 2019-01-12
    What does the log say now?
    Does the browse show both NICs? Try selecting the other NIC and change to LAN B.
    One this is downloaded, try a 'Scan for devices' from the etherCAT master context menu. What does that see?
  • apakrat - 2019-01-14
    Hi ph0010421,
    I don't know why but today when I was going to run the project to capture some pictures, it worked perfectly for me. This is the best way to begin a week.
    Thanks for your help, I very appreciate it. Hope you guys have a nice week.
    IMG: asd.png
  • Anonymous - 2019-01-14
    Great news
