"sudo"-Befehle ΓΌber die Funktion "SysProcessExecuteCommand2"
2024-02-01
2024-02-02
  • Thomas@Moba - 2024-02-01
    I need to execute "sudo" commands via CoDeSys 3.5 SP 19 P5 using the "SysProcessExecuteCommand2" function. Commands without sudo are no problem, but as soon as sudo is used in a .sh or a single command, it does not work. Command=AllowAll is entered under "SysProcess" in CODESYSControl.cfg. Nevertheless it does not work.
    Does anyone know what the problem could be?
    Greetings, Thomas
    Last edit: Thomas@Moba 2024-02-01
    eschwellinger - 2024-02-02
    just use the command without sudo then it will work!
