I am running the Codesys OPC-UA server on a RPi and want to connect nodeRED on the same system to it.
Is it possible to export the symbol configuration to a nodeset.xml?
The browsing functionality of the opc-ua-node is buggy and as the symbol configuration is static during runtime in my application it is kind of an overkill...
Thank you in advance!
Ok, I found the solution.
With Build/Generate Code a XML file is created withing the project folder.
