Codesys control for linux CmpPCANBasicDrv
2019-05-08
2019-05-14
  • Anonymous - 2019-05-08
    Originally created by: sbrauns@moog.com
    Hi All,
    I am trying to setup a can USB PCan dongle. I have it working under linux, but to be able to use it in Codesys I have to include CmpPCANBasicDrv to the CODESYControl.cfg.
    The first issue I had was that there was no [ComponentManager] in the configuration so I just added it.
    But now i get the error:
    libCmpPCANBasicDrv.so: cannot open shared object file: No such file or directory
    *** Error: Component <cmp>CmpPCANBasicDrv</cmp> NOT loaded
    Any help would be appreciated.
    thank,
    Sander
  • TimvH
    TimvH - 2019-05-12
    Probably you are trying to use this driver, because you have used it for a Windows based CODESYS Control. In Linux the standard SocketCAN driver will be loaded and CODESYS will communicate through the Linux CAN communication layer with the CAN device.
    I guess you mainly have to configure the CODESYS Runtime settings.
    See https://forum.codesys.com/viewtopic.php?t=7315 for some details.
    eschwellinger - 2019-05-12
    it turned out that there is a missing component in the Linux SL runtime,
    this will be fixed with next version.
  • Anonymous - 2019-05-13
    Hi Edwin,
    Thank you for your reply. This explains a lot.
    Is there a possibility to already get the missing module in the meantime?
    Thanks.
    Br,
    Sander
    eschwellinger - 2019-05-13
    yes might be possible... end of the week.
    Give me an email on the store support case.
  • Anonymous - 2019-05-14
    Not sure what you want me to do. My name is my Email.
    Or do you want me to open a ticket on the store for this issue?
    BR,
    Sander
