Is it possible to move a previous project from TwinCAT to CoDeSys ?
I know about the export function but it seems to not work about the whole project and I have to do it manually, one by one on the projects files.
Thank you for your help!
if you mean with Twincat -> Twincat 2-> version2 then it would be possible to
open the .pro/lib files with CODESYS V3 (Attention: You need to use the CODESYS V3 32Bit Version for doing this)
Later after import is finished I would recommend to switch to the 64Bit CODESYS Version.
(Both versions could be installed / used on the same PC without Problems.)
Thank you for the fast reply. Would it be possible to do the same from TwinCAT 3 to Codesys 3 using the same thing ?
I've managed to move single files by doing the export to Plcopen.xml even though not all the files are easily exported.
Regards
Gianluca
Regards
Gianluca
