Codesys has stopped working
2015-11-18
2015-11-19
  • Anonymous - 2015-11-18
    Hello
    I've had this problem with 3.5 SP7 patch 1, 2 and 3.
    It works well for weeks (or hours).
    When opening the program, I get a 'Codesys has stopped working' message. There doesn't seem to be a pattern.
    My solution now is uninstall/re-install.
    Do you need a log file to help?
    Paul
    eschwellinger - 2015-11-19
    in case this happens again, is it possible that you try to CODESYS via Diagnosistool.exe
    'c:\Program Files (x86)\3S CODESYS\CODESYS\Common\DiagnosisToolLauncher.exe'
    this should generate a log which should help to investigate this.
    Which Windows Version are you using and could you attach These log file or send it to the CODESYS Support?
