CAA File Library. Problems with function blocks.
mr-nik
2020-04-13
2020-04-13
  • mr-nik - 2020-04-13
    Good day, colleagues.
    I'm trying to make a algorithm for copying a file from plc to usb-flash.
    I'm using caa file library.
    I made it with CASE OF and organized "steps" of algorithm.
    And by the way, i made it like program that i call by click of the button on my visualization.
    But DirOpen function block doesn't work.
    I send execute command, but nothing happens.
    Why is that?
    Last edit: mr-nik 2020-04-13
  • aliazzz
    aliazzz - 2020-04-13
    For a working solution based on CAA library, check the following library
    https://forge.codesys.com/lib/xml-pac/home/Home/
    It contains a filemanager, see if it helps you or not
    FB_FileControl;
    This function block can open, close, read and save from and to a generic plc memory buffer
    Good luck
    Last edit: aliazzz 2020-04-13
      Thanks for this interesting point, but i want to hear about caa file library.
      Or SysDir, SysFile libraries at least.
      Or on the other hand you can give an advice about algorithm of copying.
  • i-campbell
    i-campbell - 2020-04-13
    Hmm, it extends ETrig, so it needs to see a false to true transition of the .xExecute. I can't see where you call it with .xExecute false.
