mohi - 2026-04-24
Hello,
I try to connect a Controller to Azure IoT Hub using a Root Certificate put on the controller in /etc/ssl/certs und SAS Token for IoT Hub instead of X.509 certificates.
The TLS Handshake is successful when I test in terminal using openssl. It seems that the Controller doesn't start this process. I use the Azure IoT Hub library and the Net Base Services.
Is there something left or something you can recommend?
Best regards
Mo
